The never ending build of 1062.
Galantvr41062
plymouth, MN
I was out of town 2 weeks ago, and did not have time to head down to discount steel until this saturday. So here is the start of the frame work for the removable front end.
~John
Galantvr41062
plymouth, MN
Here it is, removable fender/frame assembly.
This is the first stage of removal and about half way threw the install of the front clip. I will modify the fire wall mounts so that with a second set of hands the front clip can be removed with or with out the hood on and the front wheels on and the car with it on the ground by only removing 4 pins. All this to make it easier to work on of course.
Here it is pushed in to the correct depth.
Here are the front slip connections, these are fabricated out of 1/8" mild steel and will be fully welded to the frame when completed.
The other side bracket
I think the brackets are strong, yes this is me standing on the front core support.
Never mind, I think I might have made this structure a little to strong, this is a floor jack with a 0-600 PSI gauge on top, and it only takes about 520lbs to lift the entire front end of the car right now, so I do not need to worry much about this setup flying off the front of the car anytime soon. I thought I would just see how much pressure it could handle before it started to bend or something. Now I just need to make the front bumper cover mounts, front grill mounts, head lights/turn signal mounts, then finish weld and start to paint stuff.
~John
Galantvr41062
plymouth, MN
The reason I was showing that is there are no rules or regulations for the front of the car. All of the NHRA and IHRA rules are made to save the driver, so figuring out how to make a tubular front end and a removable front clip is a little of a stab in the dark for me. I am lacking the needed engineering degree to know what will work so I am over building the front end. I have looked at few door slammer cars and a full tube chassis car build to come up with my cars front end design.
I did get the front bumper cover mounted up tonight, here are a few pics.
~John
Looks like this is coming along nicely. Wish I would have noticed this sooner.
NateCrisman
Blairstown, NJ
Have you been keeping track of weight so far in what you cut off of OEM front end vs what you have built? Im very interested in the weight change more than anything.
Galantvr41062
plymouth, MN
The front end pieces on the ground weight about 80lbs.
Here is what replaced what was removed, minus the fenders. I estimate this weight to be about 50lbs total, but the main structure should be stronger then the factory unibody design. So in the end I saved about 30lbs of weight up front but it should be A LOT easier to work on.
~John
Galantvr41062
plymouth, MN
With the front clip done until I get a hood I moved the car forward and started to cut up the rear end of the car. So far I have found about 80lbs to remove. The rear doors are gutted minus the crash bar and the door handles to open it. The glass is held up by a bracket that is bolted to the crash bar. The truck area is cut up and I bought some thin aluminum sheet to rivet in to cove the new holes. I will remount the fuel cell and make the truck lid as light as possible and will be held on with 4 pins vs the latch and hinge setup. Then after the rear bumper is re mounted I will weigh the rolling chassis in its more complete state to see how heavy it is.
~John
Galantvr41062
plymouth, MN
That made me LOL. I was out working on the back end of the car again, long story short there will be a lexon rear windshield and about 200lbs of weight removed sense the last time it was on the scales. One step closer to the 2400lb race weight.
~John
Galantvr41062
plymouth, MN
In the process of removing the trunk lid hinges the rear glass broke, no bid deal minus the mess it made. Here a few pics of the progress. This will be a little easier to seal off the trunk area all said and done also.
~John
Wow what an amazing Build thread, one of the best ive seen. Great workmanship keep it up!
Galantvr41062
plymouth, MN
Here is the external pic of the rear deck lid.
Here is the inside shot of the rear deck lid, the interior will be painted all 1 color.
This is the passenger front wheel well.
This is the driver front wheel well, we removed a total of 6 lbs of under body coating, this included both front wheel wells and few feet of the floor pan. I would guess the under body coating is a total of 15lbs and the rest will stay on the car for now.
Here is the solid rear bushing I made to replace the rubber on the front lower control arm. This is steel and chrome moly welded and lubed with extreme high pressure grease.
Here is a shot of the welded in solid subframe mounts I made.
More to come later this week. I do have a few more pics in my album, and thanks for looking.
~John
RedTwo
New Zealand
Jeeze, the only way to make this lighter would be if it were made of paper mache! Awesome
Galantvr41062
plymouth, MN
Thanks guys, I do not like to think about the man hours so far into this project. But on a plus note its getting closer to rolling.
Rolling on all 4 again. A rear bumper cover and a hood away from a complete rolling chassis
I removed the plastic molding and cut the bottom part of the fenders off.
And solid mounted the plastic molding to the chassis, and a few zuss fasteners will hold the bottom parts of the fenders in.
The front clip now has quick release pins, which will be removable even with the hood installed.
The fuel cell is mounted and the battery box has a home, I just need to buy the thread rod for the battery tie down.
Just a few more items to finish up the chassis then its back onto getting the engine up and running, then finish mount a few items when the motor is back in the car.
~John
