A cam swap is an option. But there are reasons to keep the 280s.
For one, a higher duration lowers the helmholtz resonance rpm match for a given runner length. 272s and fp2/fp2x cams have a 2nd harmonic (very good) at about 7000rpms with the stock 1g/GVR4 runner length and area. 280s will put that strong harmonic even lower because a later effective valve close angle lowers the rpm resonant point for a given runner. If you sift through the white noise concerning helmholtz resonance and boost, you will find that
PR doesn't affect velocity of sound and that even the Porsche 911 gt2 uses the troughs (negative pulses) of the waves to cool the aircharge on a boosted v6 motor. See
here and
here for a little about Porsche's "expansion-type" manifold.
As well, from my personal experience tuning a local's car, we were able to have a VERY health midrange and decent spool speed by retarding the exhaust cam timing a few degrees and made a power band very similar to my fp2 cams with the stock intake manifold. If only 280s were available when I bought my cams. Later we could put the cams straight up and had a bit more topend. We went with cam timing to lower the powerband because another aquaintance was able to see the same powerband by doing this with a stock manifold as well. These cams were able to develop more midrange and fell down uptop like the 272s, likely because of the increased overlap which puts exhaust gases in the intake when you're really pushing your turbo (high backpressure). But they didn't fall as flat as I would have thought. Overlap increases midrange and especially spool speed. . . But know that you will have MUCHO lope. Which many like /ubbthreads/images/graemlins/smile.gif . If you can tolerate a 1000rpm idle, this will give you the bandaid you need now. And later the cams can be set up for more VE at higher rpms to get the most out of a larger turbo.
EDIT: A good exhaust manifold upgrade will help you through out the rpm range. Perhaps a little more where it's runners match the intake resonance, if you have any noticeable intake resonance.
