Terry Posten
Yes, I fixed the problem. It was several small boost leaks. I was able to fix most of then a while ago and now I am fixing the rest.
I found out that the forge unit can be clocked any way you want it to be and I did change it. BUT I caused a leak doing it. I figured out that once you clock the outlet pipe that you need to retighten the base so that the "o" ring is tight again. (I also used black silicon to make sure)
It was a stupid mistake but the ability to "clock" the output pipe is an awesome ability.
