Or tune with a low static Timing value. Like clamped at 15*Degrees, then turn the boost up to make up for the timing.
Like the analogy "Fast, cheap, reliable, pick two." Tuning has its own analogy.
"Timing, compression, boost, pick two."
And on Topic, Engine life has little to do with the internals, and more on your tune.
The 4g63 is special, we all know that. They can make 500hp stock.
But just the same, as making 500hp stock, you can rip down a built engine in two seconds, let alone 50k with a bad tune.
Stock engine (Or EVO III internals or W/E), with a perfect tune, will net your goal.
