Installing fuel pump
Well I just got done with my install of the Warlbro 190 lph pump and can report as follows:
The 1g wiring harness part number 400-857 was a 100% match
The 2g GSS250 pump fit perfectly with the exception of the area where the isolator meets the back bracket.
The isolator was too thick. I elected to run the pump without the isolator and use a tie wrap instead. The rear bracket still fit and also forms a wedge to hold the pump in place.
This pump is going nowhere.
I hope this helps someone at some point in time.
Mine was in perfect shape. Mine had a denso OEM replacement pump in there though. It was just an OEM type. Unless you are the original owner you never know what you will find, I hope you find something nice in there lool!
Enjoy!
