GSX_TC's Galant VR4 Build Thread #550/2000 (Samara)
Quoting bazeng:
Good luck with the GTR mate.
Good cars when they are taken care of. I've seem alot in shops though (more than Mitsubishi's).
They can be somewhat problematic especially with the oiling system (I've seen quite a few go into the shop for full rebuilds due to oil starvation).
Keep in mind that they have poor oil return from the head to the sump.
There are a few mods you can do but they are not fail safe.
Be sure to keep us up to date with how you go.
If you want to go all out on the GTR, do what the big boys do and buy a RB30 block with an RB26 head. 3.0 Litres of mayhem.
Here is a helpful link:
RB26 oil problem
Thank you! Yeah I know all about that problem, most likely gonna source out an N1 block and build it later, but for now I'm gonna enjoy the car as a running and driving stock GTR with cold a/c for a while before I go crazy.
Quoting slugsgomoo:
Don't know how long you're planning on driving... did you make it back, or did you get arrested /ubbthreads/images/graemlins/laugh.gif
Drove 15ish hours non stop didn't get stopped once.
mitsuturbo
Near Seattle, Washington
Quoting GSX_TC:
Quoting slugsgomoo:
Wow. That thing must have one hell of a giant fuel tank to be able to drive 15 hours non stop. /ubbthreads/images/graemlins/smirk.gif
Well the time for me getting my dream wheels (Work Meisters) on Samara is getting closer. Since the new wheels will be in the EVO X spec in order to later run EVO X brembos I'll need that size and offset. Only problem is that the car will need to be raised a bit and a little camber to fit the wider tires. So Mike and Tim from FIST Racing just installed the Coilovers that I had been sitting on for nearly 2 years Lol. Now I have go pick up the wheels this Sunday in Austin, then buy the tires and have them mounted. Then straight to get the Coilovers aligned and setup properly.
Here are some pics of the Coilovers installed. Besides the car needing an alignment the ride quality has improved a great deal now. It takes bumps a lot better now as well.
I'd be weary of ordering Work wheels simply because they match the specs of the Evo wheels. The biggest issue with the Work wheels (and most wheels for that matter) in regard to brake clearance, is the spoke design. I think you'll find the Work wheels just aren't big brake friendly. With spacers, I'm at a +20 up front to clear 3KGT brakes, which is a ridiculously low offset for our cars. I was just having a discussion with someone on DSMtuners the other day, who said the the Evo Brembos require just as much clearance as the 3KGT calipers. If that's true, it means you'll need a sh*t ton of clearance up front. In addition, I wouldn't go with 18s (I'm assuming you mean you're matching the specs of the Evo 10 wheels you fitted earlier in this thread). The larger diameter wheel will just give you more fender clearance issues, and I doubt it will yield you much more brake clearance.
If you have the option to specify the size and specs of the Works you're getting, I'd triple measure before I paid for anything. I'm not sure simply matching the specs of the Evo wheels will give you the best fitment, or even fit at all for that matter. You're probably going to be in the +25 to +20 range to clear those brakes on Work Meisters. You're also going to be kicking yourself in the ass if you buy wheels, and then need to install spacers afterwards.
bobdole
U.K.
If Mike ordered them for the Evo X fitment, they will be "big caliper" clearance. They will clear with out spacers. Mike what specs did you order/get?
bobdole
U.K.
Quoting GSTwithPSI:
Since your Work wheels are 4lug. They are most likely "standard clearance" which is why they don't clear. I am in the same boat with my 4lug Work wheel I have on order. They are "standard clearance" so I will have to run a 10mm spacer. If I had 5 lug I could order in "big caliper" which I know would have cleared easy as I sent Work a template of the brakes. Work wheels are BBK friendly if you know what you are doing and order the correct spec.
I didn't have the luxury of getting the "big caliper" Work wheels, as I picked mine up used. Is that even an option offered for the 4 lug Work wheel? I got a great deal on my set of Work wheels, which is why I even picked them up. Finding a quality wheel in 4.114 with decent specs is damn near impossible. Even the BBS LMs I had needed to be spaced out to clear the 3KGT calipers.
The Evo wheels (Evo 8 and 10) clear big brakes so well because of the flat spoke design. The concave spoke design of the Work wheels (Meisters specifically) doesn't play well with the large calipers. I'd be interested to see what the difference in spoke design is for these "big caliper" Work wheels. The spoke design would have to be modified, otherwise decreasing the offset is the only other option to increase clearance.
CutlassJim
Manchester, NH
I have Enkei NT03+M's on my Lexus and the difference in spoke design is crazy on the fronts to fit over the Supra calipers. The rear wheels wont even bolt on the front even though they are an inch wider.
