Joe, thanks for the post. We welcome any vendor participation in our little community. You'll find that your presence on the board will eventually help you sell more product, and with constructive feedback, a better product.
I am hoping that becoming an active member of the community will help us improve our kit through feedback from our customers. We've sold a few of these Galant VR4 kits, but rarely hear back from the customers whether anything could have been improved or anything included in the kit to make it easier to install. Your feedback is greatly appreciated.
I removed the bracket and cut off the three ends to re-use as spacers at their stock locations. I've got that lower right bolt finger-tight now, but it's impossible to get a wrench on it. There's not enough room around the head of the bolt to even get a wrench head to slide onto it. That aluminum colored piece (below the bolt) with the coolant lines running to it is in the way; I think it's the FIAV. I can't get a socket to it either because the piping prevents a good straight shot to the bolt head. Like I said before, a little more piping running straight off the TB would probably help. I'm going to try to locate a shorter bolt, toss the bracket that I'm using as a spacer and see if that helps with access to the head of the bolt.
I think removing the spacers altogether and using shorter bolts would be the best solution. The spacers move the bolt farther away from the flange and closer to the pipe, making it difficult to get a wrench on the head. I think the placement of the bolt is just in a bad place. Do you think a shorter bolt with a smaller head would fit better, or a bolt with an allen head would be better?
I think I'm going to take you up on this offer Joe. I'll contact you off-list about it. Most of us with cars in this state of modification (probably half the members on the board) have moved the battery to the trunk and are taking cool air from behind the passenger headlight using some sort of simple 1G intake pipe. Most of us run recirc too, just like stock. Even if I had my stock BPV mounted on your flange, it's still too close to being INSIDE the fan shroud. Just an inch or two farther up the pipe would be perfect. You should consider offering an intake pipe that allows the MAS to be positioned behind the headlight. The following picture illustrates the typical MAS placement in a modified GVR4:
Since we have a GVR4 here, I will see if we have it long enough to build a new intake kit for it which relocates it to the fender where the battery normally is.. We will also try a couple bolt options on that lower bolt to see what would be easier to get to and tighten down.
The last picture is of the inside of the pipe off the turbo, where it expands to a larger diameter and then bends to run parallel to the radiator. There was some welding rod on the inside at the seam.
That is not acceptable. This should have been noticed and deburred during the build process and the cleaning process. I will be sure to go over this with our shop and make sure all of the pipes are inspected. I believe since this was a stainless kit, the pre-powdercoat inspection was not done since that is the time when the piping is deburred. We will send you a new blow off valve pipe and a new J-Pipe. We will 2 day air it to you so you have it by the weekend so you can go out and have some fun..
Here is a picture of the original kit we built and built our jigs off of. We will be fitting our piping on this new Galant and see if there are any other options for blow off valve location. We located the flange where it is to allow it to recirc with our intake pipe, and we built our intake pipe to make our kit as "bolt on" as possible (ie not having to relocate the battery). That's one of the key points we try to make with our kits (any kit) is the least amount of modification for fitment. Building another intake for those that don't mind relocating the battery would be a good option.
I sent an email to you all yesterday with my suggestions to make it a slightly better fitting kit. Take or leave any/all of my comments.
I have not received an email, but we have been having issues with our mail server. If you sent it to
sales@extremeturbosystems.com or
jr@extremeturbosystems.com I'm sure we will receive it. If you sent it to our old aol or netzero account, we may not receive it.
Joe Schesso
Extreme Turbo Systems
