deleted abs, now the anti lock lights's on
I unplugged the long connector to the abs computer in the trunk next to the antenna. Then I finally figured out which fuses to pull on the battery terminal (my car didn't come with the cover so I had to search through the members ride forum for a pic close enough to make out which were the right ones. It's the yellow 60a that is bolted in from both sides; not the bottom, and the blue 20a next to that). The abs pump unit is still in the car and the PO had disconnected the 2 wire plug from it already.
When I started the car the ABS light was still on, I pulled the other 2 connectors above the pump and now It's gone. Thanks a lot for the info, this will make inspections easier /ubbthreads/images/graemlins/smile.gif
