Not sure what sorta vehicle safety inspections they have over there, but if they expect to see the light come on then turn off when you start the car, it's pretty simple to just rewire it in parallel with the check engine light.
The yellow one in the fusible link by the battery... it is bolted in from the bottom.
That will only disable the ABS, you'll need to do some other stuff to get the light to shut off. If you'd answer my initial question I could probably help you. The systems are different from 91 to 92.
I take it that the pump is still there? You'll need to unplug that, too. I forget which one, I think the big one in the middle... but answer John's question and he'll help you out. /ubbthreads/images/graemlins/smile.gif
You need to unplug the ABS computer in the trunk by the jack. That will remove one system that turns on the light. Then you need to unplug the two wire plug under the hood on the driver's side near the front. I think its the one that Hertz said but if you unplug all two or three of those plugs it won't matter since they're all ABS related. I'll take a look in my manual and get you some wire colors before I head out for the day.
Thanks Jeff, I will be trying everything listed in this thread. John suggested a difference between the 2 years and I was hoping for the info on the 92s. Thanks again.
