car stalls after running for 3 minutes
Galantvr4559
Denver, CO
Can u keep it running? And maybe cam position sensor. My car did something similar. Got warmed up and just stopped working.
pauleyman
Oklahoma City, OK
Heat can affect electrical components. Does it restart? It dies like you shut it off or sputters and dies? If it dies like you shut it off likely some electrical component is failing. Ignition transistor can do this. Does it start again after it cools off? A quick and dirty test for the transistor. After the car dies does the tach twitch when you try and start it? If it doesn't test the transistor. Are all connectors solid and not intermittent? Only a handful of electrical components will completely shut the car off like you turned the key. That is what you are describing correct?
Mine did the exact same thing until I sent my throttle body to Steve at throttlebodys.com now everything is perfect
Launch
Texas
Palm/logger? ... should be one of your first buys after purchasing one of these cars.
MAS plug tight and secure?
FlyingEagle
THE Ottawa
I had an ECU that went bad, and once it warmed up it would cycle the MPI relay on and off, might not stall, but serious stumble, occasional stall yes. Another important spot to learn. /ubbthreads/images/graemlins/grin.gif
