broken tranny
gmp
Denver,co
So,
i was driving around doing errands yesterday driving real easy.I went to shift from 1st to 2nd and the clutch pedal went to the floor.So i thought sh*t master cly. or maybe a busted hose.I pulled over and looked under the car only to find no leak but did see the master cly was pushed way out on the "throw-out bearning fork?".I figured maybe it just got stuck so i wiggled it and BAM!the bottom half of the fork comes out broken hhaha....
if i didn't have bad luck i would have none at all.
pictures to come
Anyways i have a spare tranny i can steal a replacement from.I'm just wondering has anyone done this,and does someone make a stronger replacement?
thanks
gmp
#20
213of1000 is truley cursed with me owning it /ubbthreads/images/graemlins/devil.gif
Barnes
Richland, WA
This not terribly uncommon. Mitsubishi redesigned the clutch fork to something much stronger. You probably had the old style fork. Buy a NEW updated fork and fulcrum ball.
That's still more of a clutch related item than a transmission piece. Just get a new factory one as well as a new fulcrum ball and install them.
gmp
Denver,co
ok great thanks fellas,can i get this thru mitsu or should i go to somone else?
I don't think they're terribly expensive. I get a discount at my local dealer so most stuff I buy through them. If you don't get a deal, just go through JNZ or another DSM parts supplier.
boostedinaz
Scottsdale, AZ
Try a local dealer or JNZ. A few years back when I bought new ones I think the set was about 60.00, but like I said that was a few years ago.
rgeier11
Chicago Suburbs, IL
Everything will cost you less than $100 including good transmission fluid. I had this happen in my Talon after only 20 miles on a new engine rebuild. Had to rip it all apart again. /ubbthreads/images/graemlins/banghead.gif
gmp
Denver,co
ah that ould sucj i have aleast gotten 3000 out of the tranny sense it was out of the car.Well i been sick for the last few days but i think ill run up to the mitsu dealer today to see what i can come up with. thanks guys
belize1334
Bozeman, MT
You can also get a new ball and fork from RoadRaceEngineering.com. They recommend them with all of their clutch replacements so they have a bunch in stock at any given time.
DSSA
PA
gmp
Denver,co
i got a deal from a mitsu dealer here in town, thanks for the price and the reponse...
