Clutch dragging after new ACT2600
yubh8tn
coeur d alene, idaho
I had a somewhat similar problem recently except it DID get worse. I decided to bleed it again for the 3rd time, except this time, when my buddy pressed the clutch pedal in, I noticed the whole trans moved just a little. There's a bolt that goes through the trans into the block right next to the slave and that puppy was hand-tight. I torqued it to spec and now it shifts great as the slave isn't moving the entire transmission... lol
check it and see if its loose or missing?
yeti
san diego california
Your a life saver, I’ve been bleeding by myself with a wood block.
Had my gf step on the clutch and noticed a giant crack pushing the tranny away with each thrust of the slave cylinder.
Cheese and rice
