broxma
Having been several weeks since any updates, I'll start with the skinny.
The Evo 8 ECU is now installed, EvoScan is working well. I flashed a modded rom for my 2G mas and the car has been running pleasantly for several weeks now. It needs the wideband and Boost gauge install which is going to happen as soon as I build the plate for it this weekend.
I had to replace the front struts. The ones that came with the car were very bouncy and I wasn't happy I left them. Thanks to that guy who sold them to me on the cheap, they worked great.
I fixed the sole oil leak at the oil filter housing line. So far, no more leaks but the dipstick is blowing out now.
The motor has about 400 miles on the rebuild so I figure it's about time to really make some magic. I bought the AGP 3147 off these forums here. It arrived looking brand new, so I set about getting a manifold and Wastegate for it.
Turbo mounted to the manifold. If it looks like an Ebay (AMK?) manifold that is because it is. I am going to run SS rods from the head flang to the turbo flange like my DNP Evo Manifold. This one, actually, pretty nice. The welds are TIG obviously, but clearly hand welded, which is ehh, but they look good, good penetration, it even came with SS studs and lock nuts, the studs even have a wrench spot. The Flange was already tapped for the studs.
The whole turbo setup. That is an Autoteq Wastegate. Not my first choice but I did some looking. It is unfortunately 38mm and the manifold is setup for 35 so I'll have to either weld a new flange on or open this one up a bit, no big deal.
I cleaned these up. I decided, I am putting these on the color they are. The Motif of my car is basically green and gray so I am going to enamel the MITSUBISHI in green and leave them gray. The brackets are already on order and should be here soon. Of course I need some shoes to go over these big boys so...
I refinished my Evo 9 Wheels. These were originally on my Evo but since I bought the drag DR-31's for it, I had these laying around. The previous owner had rattle canned them black and did a pretty bad job. I bought 7 cans of Paint stripper and over the course of two days ended up with these. The paint stripper actually took the black and the factory paint off which I don't mind. I like the new look. I'll just throw either some clear on them or just wax the machined surface. Tires are going to be Riken (Yes you heard right, they are rebadged Michelins without a warranty, don't waste your money) 235 45 r17. They are Z-rated and can be had about 76.00 a corner.
Plans are to get the turbo and Intercooler on well before the Mitsu Shootout in June and have some time to tune the thing. I am pulling the FIC 1050's from my Evo and putting stocker back on it since the wife will be running it at or just above stock boost levels. I'll need more overhead with the bigger turbo and may consider switching to E85 if I can get a station within 10 miles of my house.
The Evo MAF will go on with the turbo/IC so I can reset the MAF settings to stock on the ECU. Big fan of this since the 2G setting are not quite clear and I don't have a MAF Adder table on my rom.
That is all. I will update the Evo 8 ECU thread in the how to as I am able. As always, any questions about anything you see, PM and I'll try and answer. The Turbo and IC install will have a full write up even though it isn't going to be a do it at home project. I figure maybe someone will like to see how custom stuff gets done in case they think doing that type of work is "easy".
/brox
/brox
