1988 Galant VR4 JDM Mad Tyte Yo Edition
Quoting fuel:
JDM is Sophia White not Summit White
Different color code or just the name?
dkvr4
CT
Quoting caanglin:
LED license plate lights.
What did you use on the license plate as a bracket for a American plate?
G
zompton
I would like to buy a set. Anyone have his contact info?
caanglin
Active member
Jefferson, GA
Quoting 92_talon_awd:
^^Looks like he used something similar to these click
That's exactly what I used. I just PM'd him on Zilva. They showed up in like a week.
cheekychimp
East Sussex, U.K.
Looking extremely hot! I'm glad you got that offset sorted out ...
... it was looking a tad aggressive /ubbthreads/images/graemlins/rofl.gif /ubbthreads/images/graemlins/rofl.gif /ubbthreads/images/graemlins/rofl.gif
Looks great. Crazy how direct sunlight makes the wheels look a completely different color. Beautiful car, man.
caanglin
Active member
Jefferson, GA
Some updates...
Ground Control coil-overs
Fuel pump rewire. I should not have noticed the difference it made, kind of worrying. Makes me feel like I should of had a wide-band a long time ago. /ubbthreads/images/graemlins/shocked.gif
Grams wide-band
Apexi SAFC
Disrupter
Active member
Long Island, NY
Are the rears flush with the rear fenders? It kinda looks like they are not. Other than that the car looks like butt secks.
caanglin
Active member
Jefferson, GA
Quoting Disrupter:
No. The camber is crazy negative right now. I can't seem to find the DIY camber kit/guide some people reference.
Running camber bolts up front. I need to dial in a little more negative camber up front. It still rubs a little.
Quoting Disrupter:
The rear wheels on the VR-4 always appear sunken in when compared to the fronts. It's a commonly known issue (although, not really an issue aside from a cosmetic standpoint) on the Galant VR-4. As a solution, many people run a 5mm spacer in the rear to bring all 4 corners flush. A quick search will yield tons of results about this problem.
OP, I'd bump the ride height up a bit. I'd add negative camber only as a last resort.
