Figured out the problem with the alternator after checking the wiring 3 times, measuring voltage at every connection, additional 3 ground straps, pulling the gauge cluster out and checked the bulb...sure enough it wasn't blown out. Had continuity from the gauge cluster bulb to the alternator plug. I couldn't find anything in the wiring that was wrong! After putting the spare alt in out of frustration trying to get the dash light to work, I felt the plug push in about 1/4 more than before!
There is a little orange silicone bushing/seal thing on the alternator plug. Seems there was also one jammed into the hole in the original alternator too, thus the plug wasn't going far enough in to make contact.
Just as well I pulled the intake to remove the alt, as I never would have been able to see the second seal inside the alternator with it on the car. I figured it out after getting frustrated and putting the spare alt in and feeling the plug push in about 1/4" more! Dash battery light also started working once the alt plug would seat in far enough.
So I drove the car up the road about 5 miles. Holy crap it's loud and vibrates alot. Guess BSE kit + ES bushings + Poly engine mounts isn't going to be a cadillac ride. The super stiff coilovers will make it even worse
Tonight I'm going back to re-bleed the brakes (they are super mushy - unsafe), wire in the 4 headlight plugs, put on the front bumper and blinker lights, and bolt on the rear bumper. I'm so behind schedule Im just going to put the complete bumper assembly from #931 on since there are no broken bolts and it will go on in 5 minutes. I'll delete the rear bumper support in september when I have more free time. What little time I have before Friday/sunday racetrack days is better spent on tuning and setup and putting miles on it than sitting in the garage making brackets. So the car will hit Etown's scales 50lb+ heavier than expected. oh well./ubbthreads/images/graemlins/wink.gif
I'm going to adjust the tie rods for a little more toe in, and try to get the rear camber to 0 so I don't kill the tires too bad driving it around this weekend.
Oh yeah...Brent @ JMF sent me a new coil bracket...fits like a glove now, no more having to take the bracket off from the bottom, as it doesn't block the intake manifold bolt now. YEAH Brent = :heart:
