Where should i buy axles?
gvr4144
loveland Colorado
Was thinking about autozone axels for the life time warranty. Witch is nice, but i dont want them to break right away seeing how they will be for a high hp application.
G
zompton
See if you can find a local re builder where you can take your OE axles in and have them rebuilt.
Vader
Active member
Portland, OR
I've always had luck with empi axles although for my mitsu i only used the bearing and cage assembly. I removed the bearing/cage assembly and used the mitsu shaft with a synthetic grease blend. I've got around 3k miles on them so far with no noise! I haven't really started to make any snort with the car yet though (250-280hp estimated). If your looking for a really high hp application axle i would suggest looking in to the drive shaft shop, prepare to be bent over and taken for a hard ride though /ubbthreads/images/graemlins/jawdrop.gif
mitsuturbo
Near Seattle, Washington
If you're going for such high hp numbers that stock axles won't do, then you're going to be shelling out a ton of money for stronger ones all the way around. Auto zone only sells front axles afaik and they generally have no issue handling power. If you're not making enough power to worry about twisting u joints apart or grenading transfer cases, just go with the duralast gold sh*t.
GVR4kauai
I'm running napa axles in the front and they are really nice, well built axles.
slugsgomoo
Tacoma, WA
The likelihood you already have remans is pretty high in my experience, with the car being as old as it is. One way to tell is that the boot will have scallops on it.
All that said, buy the lifetime autozone axles, I never hear of anyone breaking fronts. Rear end, rear axles, driveshaft joints & t-case seem to break long before then. Unless you're already breaking drivetrain parts, you don't need to spend huge money on raxles or OEM IMO.
manikbastrd
I have napa crapa axles and they work fine, but I only make 315 AWHP. I have broken a rear axle (oem) at that hp though...don't know if that helps at all. I also have searched everywhere for rears and can't find them except for the junkyard.
gvr4144
loveland Colorado
Thanks fellas, im just going to buy the duralast golds for the front and leave the back ones stock. See what happens.
bowler31185
Active member
St Petersburg, FL
If you are looking for a little more than stock but not insane there is a couple levels up from Driveshaftshop.com. They do have front and rear in a 600hp level and a 1000hp level.
Quoting mikus:
^ that'll do but add one vote for RAXLES and really they're not very expensive.
Last I heard, Raxles did not make parts for these cars anymore. Maybe that is wrong info though.
gvr4144
loveland Colorado
I contacted raxles and this is what i got. Also i couldn't find any direct links for the vr4 only custom axles...
