Street 182
182/1000
Specs
Ownership Status
Currently Own
Year
1992
Production Number
182
Mods-Power
Intake
- AMS VSR [www.automotorsports.com] *Ebay Auction, last one made $600.00
- ’90 NT Throttlebody *Tapered/Polished bore/Removed all four Vacuum Ports [www.throttlebodys.com] / [89Mirageman]$165.00
- K&N Air Filter part no. E-2875 [Advance AutoParts] $43.28
- 2.5" to 2.75" Silicone 90° Elbow [www.siliconintakes.com] $19.99
- 2.5” to 1.75” 45° Degree Elbow [www.siliconeintakes.com]$19.99
- T-Bolt Clamp 3”, 2.75”, 2.0”, 2’ Ft. Straight Aluminum pipe [www.siliconeintakes.com] $20.19
Total = $870.11
Exhaust
- EVO III Exhaust Manifold [www.eBay.com] $110.66
- EVO III O2 Housing [www.ebay.com] $95.66
- RRE Downpipe 2.5” – 3” [www.roadraceengineering.com] $230.00
- RRE Cat-Back Exhaust 3” [www.roadraceengineering.com] $430.00
- HKS Carbon-Ti Muffler [www.extremepsi.com] $375.00
- Stainless Steel Exhaust Manifold Kit [www.jnztuning.net] $39.99
- 4 Layer Metal Exhaust Manifold Gasket [www.roadraceengineering.com] $34.00
- 7cm SS Turbine Housing [www.roadraceengineering.com]
Total $1,164.66
Head
- HKS Camshafts 272 part no. 2202-RM005 [www.extremepsi.com] $329.00
- HKS Camshaft 272 part no. 2202-RM006 [www.extremepsi.com] $329.00
- Valve Cover Hex Bolts [www.extremepsi.com] $14.95
- Felpro/Valve Stem Seal part no. SS70359 [AutoZone] $28.99
Total =$701.94
Misc
- Stainless Steel DSM 4g63 Water Pipe [www.ravenfabrications.com]
$270.00
- JM Fabrications Coil Bracket part no JMF DSM-CPBKT-00 [www.jnztuning.net] $39.99
- Stainless Steel “Fuel Feed” Upgrade Kit part no PSI-FPRK-Feed-O [www.extremepsi.com] $59.95
- Extreme PSI DSM 4g63T Stainless Steel Valve Cover Bolt Set part no PSI-VCBK [www.extremepsi.com] $14.95
- 1g DSM Non-Cruise Cable part no MB539465 [www.jnztuning.net] $42.20
- Odyssey Battery part no PC680MJT-A [odysseybattery.com] $137.67
- Justin Warren Battery Relocation *Trunk $160.00
Mods-Drivetrain
- 3.5” Heavy Duty Driveshaft part no MISH3-HD [The Drive Shaft Shop] $818.54
- South Bend Clutch part no K05048 HD OFE [South Bend Clutch] $372.30
- ACT StreetLite Flywheel [www.extremepsi.com] $259.25
- 1g T/E/L Shifter *Donor 1g
- Symborski Shifter Kit part no SYM-2155591[www.extremepsi.com] $36.00
Mods-Handling
- ABS Delete Line Kit part no JNZ GVR4/1G-NON ABS [www.jnztuning.net] $108.99
- 3g Eclipse Brake Master Cylinder-NON ABS 17/16” part no MR475973 [www.jnztuning.net] $111.99
- Non-ABS Proportioning Valve part no MB8955431 [www.jnztuning.net] $94.99
- Stainless Steel Brake Lines part no. TN-E39ASSBL [www.tunersnation.com] $ 119.00
- Whiteline Front Swaybar 24mm Non-Adjustable part no. BMF60X [www.tunersnation.com]
$253.92
- Whiteline 22mm Adjustable Rear Swaybar part no. BMR60Z [www.tunersnation.com] $187.00
- Cusco Strut Tower Bar OS, Front part no. 517 540 A [member: RvlutionMtrsport] $ 180.00
- Cusco Strut Tower Bar OS, Rear part no. 517 541 A [member: RvlutionMtrsport] $ 330.00
Mods-Interior
- ARC Titanium Shift Knob part no AN4502 [www.lancershop.com] $109.95
- Momo Steering Wheel w/ Boss Kit [member: mx4] $ 130.00
- Curtis DIN Gauge Panel [member: Curtis]) $ ?
- HKS Glovebox Gauge Pod
- HKS Turbo Timer III *BNIB [www.eBay.com] $99.99
- HKS Turbo Timer Harness part no GRE-15930002 [www.extremepsi.com] $15.00
- VDO Boost Gauge part no 150-121 [egauges.com] $30.00
- VDO Water Temp Gauge part no 180-101 [egauges.com] $38.75
- Alpine Headunit part no CDA-117 [www.Crutchfield.com] $349.99
Car information
Added by
pot
Views
1,235
Last update
More in 1991-1992 Galant VR-4
