some brake issues
91GSR
Newport News, VA
starting yesterday while i was driving around town, i noticed that my brakes are acting kinda funny. if i really jam on them nothing funny happens i jsut stop faster, but if i am rolling to a stop (like at a light or a stopp sign) and lightly press my brakes, sometimes i get kinda a scratchy feeling in the pedal, like something is stuck on the rotor. is there a quick easy check to see if the rotor is warped or if i have a bad caliper or pads? i dont wanna fully take apart the brakes, just figure out what the funny noises and feelings are.
curtis
Clarksville TN
You could have a rock stuck between the pad and the rotor or the pads are just shot. Look at the rotor and check for groves on the front and back and look at the pad thickness as well. As for checking for warp jack up the car and spin the wheels and listen for a rub nothing rub. Hard to make sound effects while typing. /ubbthreads/images/graemlins/grin.gif
91GSR
Newport News, VA
i get what ur sayin lol. i will check it out when i get home.
dsmless
tucson,az
also a warped rotor will make the steering wheel jerk side to side when braking and you will feel a vibration coming thru, check for a rock or sand in the pads, also it could be your rear brakes going on you, check the rotors front and back for wear groves or one side worn out more than the other
curtis
Clarksville TN
Another thing to check after a drive is temperature of the rotors compared to the others. I had a pass rear not release one time and after changing lines, bleeding the system, and tearing the caliper apart found that it was all caused by the square piston seal in the caliper. Over time the brake fluid had caused it to swell and drag on the piston. I replaced it with a normal o ring from the oring cabinet at advance and its still in there 8 years later. Yotal cost to replace was like 52 cents.
Terry Posten
Davenport, Iowa USA
^^^ Yes, rears stick sometimes.^^^
How can you tell?
Smoke rolling out of the rim and rotor glowing red is a good clue. Ask me how I know. /ubbthreads/images/graemlins/crazy.gif
91GSR
Newport News, VA
i had a caliper stick in another car i owned. i know it isnt that. is way to noticeable to be that lol. i will check the wear on them and see whats up. also i know it isnt the rear because i hear the noise up front. kinda a scratching. sometimes the wheel kinda moves from side to side but never jerks. i am confident it is in the front brakes, just dont know what. i will check for rocks and such when i work on it all tomorrow.
