VR_IV_MR
For the most part if its listed here, it means I've replaced it while I have owned the car. This is within the last 11k miles/3 years. Theres about 155,000 on her, I bought her with 144k. Only things with a * in front of them were done by the previous owner.
ENGINE
OEM 1g rods
OEM 2g pistons
ACL Race bearings
balance shafts removed
grind and polish crankshaft
bore&hone block
3 angle valve job
balanced rotating assembly
OEM ITM Oil Pump Assembly
OEM 3g Lifters
Poly mounts on rear, front
OEM mounts on timing belt side, and transmission side
OEM Gates Racing Kevlar Belt
NGK Wires & BPR7ES Plugs
OEM Crank pulley
OEM Timing equipment
ARP L19's
OEM 4 Layer Head Gasket
Magnus Heat Barrier Intake Gasket
[FUEL]
*OEM Evo IX Fuel Pump
OEM Evo IX Fuel Injectors 560cc
[AIR]
OEM 1990 Non Turbo Throttle body bored to 63mm click
OEM Evo IX MAF Sensor
*OEM Ported EVO III 16g turbo
*OEM Ported 2g DSM Manifold
*OEM Ported O2 Housing
ETS FMIC kit
3" Turbo-back. Borla Res in place of cat, Apexi N1 Muffler
[GOODIES]
ECMLink V3
Defi Link System w/ Display & Tach (water temp, oil temp, oil pressure being installed)
HKS Type 1 Turbo Timer
SUSPENSION
Tein HA coilovers + camber plates
Whiteline front + rear swaybars, bushings, etc
Custom made maximal performance control arms
*Energy Suspension bushings in the front
Jay Racing Active toe elimination
Front & Rear subframe completely rebuilt
16x7 w/ 225/50/16 Continental ExtremeContact DWS
*15x6 stock wheels w/ snow tires (215/65/15) Bridgestone Blizzak
DRIVETRAIN
ACT 2600 w/ Street disk & stainless line
TTR rebuilt transmission with 4-spyder center differential and 10% taller Evo3 5th gear
*4 bolt rear end
*New PS front axle
*New DS rear wheel bearings/seals
*BRAND NEW transfer case and upgraded yoke
*BG Synchroshift (tranny shifts AWESOME!!!)
[OTHER]
ABS Removed
AWS Removed
Oil Catchcan
- ST sway bar *** no more
- AWS delete (converted to DSM steering rack, PS reservoir and PS lines)*** no more
ENGINE
OEM 1g rods
OEM 2g pistons
ACL Race bearings
bore&hone block
3 angle valve job
OEM 3g Lifters
OEM Crank pulley
ARP L19's
[FUEL]
[AIR]
ETS FMIC kit
[GOODIES]
ECMLink V3
SUSPENSION
DRIVETRAIN
*4 bolt rear end
*New PS front axle
[OTHER]
ABS Removed
AWS Removed
Oil Catchcan
