Sandblasting Brake Calipers
SmoothCustomer
Lexington, KY
Is it worth it, and is it safe? Of course I would remove the piston, seals and bleeder valve but are there still too many places for media to get stuck in? I'm really just trying to remove paint.
89Mirageman
Stantonsburg, NC
I found it easier to use a bench grinder with a wire brush on one end to clean the calipers and brackets. I just used some gloves and safety glasses and kept turning the parts to get in all the crevices. I also have a blast cabinet but would much rather use the wire brush.
What if your planning on having the calipers powdercoated? Is a wire wheel still the best?
89Mirageman
Stantonsburg, NC
I was able to get mine down to bare metal with the wire wheel. A blast cabinet will work too if you tape off all of the holes really well and clean them afterwords.
