Radiator fitment help!
losermakesgood
Mishawaka, IN
I have a vrsf fmic and a td06 20g ready to go in the galant. Problem is fitment with the stock radiator. Basically the passenger side piping of the intercooler clearing the radiator and the fan clearing the wastegate of the down firing turbo. I would prefer to keep it seeing as how money is a little tight right now. So I was wondering what those of you with similar setups are doing? Thought about clocking the turbo and using a J pipe and cutting a few rows on the radiator. Is any of that possible and still use stock mounting of the radiator, etc? Thanks for any info! Also wanted to add that I don't have ac installed if that matters.
losermakesgood
Mishawaka, IN
I will try to get some pics posted up tomorrow. No point really since the entire front of the car is tore apart. I'm just trying to not go the route of a scirocco radiator and spend more money I don't have right now along with another project that I'm starting to run out of patience with.
losermakesgood
Mishawaka, IN
I think I've just decided to go with a scirocco aluminum radiator setup. Anyone with this setup have any good info? A write up of sorts?
Search...... Been done, over and over, and over
desant78
Clarksboro, NJ
I'll post pics tomorrow. I'm doing the same!e set up.
