Noob ECMlink V3 Question
So I just got a 1G ECM link V3 kit in the mail. The data cable is a USB on one end, and a OBD II connector on the other. Is this the right cable? And if so, do I need some kind of adapter to go from the OBD II ECMlink cable to the 1G data connector?
rdomeck
Indianapolis, In.
That is the right cable, it should be the same for OBD-1 or OBD-2 according to the link above.
Racah15
Colorado springs CO
You ordered or bought DSMLink for a 2g DSM. You could have also ordered dsmlink for 1g but have mistakenly been given dsmlink for a 2g. You need to contact someone from DSMLink and ask if you can return it, or sell it and buy dsmlink for 1g. That will not work unless you are running a 2g ecu/obd II. All this is assuming you took that picture yourself.
EHmotorsports
Beaverton
You need the 1g dsm diag cable not an OBD2 cable.
Quoting Racah15:
Sorry, that was just a generic picture I found online. I got a 1G V3 chip, but received a 2G OBD II cable. I just wanted to make sure that ECMtuning is still in fact shipping cables made specifically for the 1G data connector, and that I don't need some adapter or something to utilize the 2G OBD II cable I received.
Here's a pic of what I actually got:
Soooo did I just get shipped the wrong cable???
Looks like you were shipped the wrong cable, since it looks like you have the correct chip. Call them and I'm sure they'll get it sorted out for you.
Looks like they did indeed send me the wrong cable. Emailed them last night and already have one on the way! The guys at ECMtuning are awesome. Thanks for the help guys.
