Fog Lights
How do you replace the bulb in the foglights? I took it out but couldnt figure out how to get to the bulb. Help.
pot
Fayetteville, NC
From behind the foglight itself -You should be able to do this w/o raising the car unless you've lowered it. Behind the light is a connector. Unplug it, and if memory serves me theres a metal clip that retains the bulb.
AuSpecVr4
Brisbane, QLD
Honeslty its worth just removing the 2x 8mm bolts from the front up the top and slide the whole light out. With that much handspace up there with the intercooler piping and what else its very hard to move around. I changed mine in 10 minutes by removing the fog light completely.
PTLourenco
Active member
Southern Massachusetts
unless they are rusted up, then forget about. Just go from the rear pop the rubber seal off & squeeze the metal clip and turn it outward. /ubbthreads/images/graemlins/smile.gif
