external wastegate
tintoy
philippines
Hi.. need help. Looking for an external wastegate diagram to where should i connect the top port and lower port of the wastegate. And also i'll be using a manual boost controller. Thank u i advance.
mitsuturbo
Near Seattle, Washington
With a MBC you would be using ONLY the lower port. The top one will remain unused.
I haven't used a MBC or ran single port in a very very long time, so i'll let someone else comment on where is best to tap for the boost source in this case.
vr4play
Cincinnati, Ohio
Lower port only and from a non vacuum source. Any where in between the throttle body and the turbo is fine. Most of the time I go right out of the turbo, there is usually a nipple. If not then I drill and tap and make a nipple.
