Software Upgraded - Reset Your Password to Login
Did you adjust the clutch pedal assembly or just check it's condition. If you haven't already, watch Jack's video on adjusting the clutch pedal assembly. click
Push the clutch to the floor then let it back out. Now put your foot under the pedal and try and see if you can pull up on it. If you can the clutch pedal is worn out
