Changing out fuel filter
4G63_GSR
wis
I plan on swapping out a possible bad fuel filter (boost and higher powerband issues) and was wondering if there's a fuel plug I need to disconnect to relieve the pump. I've only done so on a 2g and that was like 5 years ago. Let me know. Thanks.
I just start the car and disconnect the pump in the back. Easy to get to and it will stall out when fuel pressure drops. That way theres no fuel pressure to spray out everywhere.
Edit* I will still leak, just not nearly as bad, so have some rags ready.*
dandanger
Finland
I did exactly the same prove did. Or actually disconnected the pump first and then started the car but thats trivial..
If it's been sitting there for long like mine (over 20 years) it can been tough to get loose but dont give up /ubbthreads/images/graemlins/cool.gif
4G63_GSR
wis
I've told my brother to soak top and bottom with PB Blaster starting tonight and hope to swap it out this weekend. I think we need all the time we can get when it comes to soaking it.
Thanks guys.
pot
Fayetteville, NC
I would also highly encourage you to use a flare nut wrench for the fitting on the bottom of the fuel filter. Otherwise you quickly run the risk of stripping the fitting.
Add to that, a quality flare tool. 14mm if I remember right.
gvr4ever
central Indiana
I usually just let it sit over night and change it out the next day. Fuel will still spill out, but I've never had it spray on me.
Wookalar
Arizona USSA
Quoting pot:
Agreed.
Can't one just open the gas cap to relieve pressure in the system? Some fuel will still spill out but pressure isn't as high. I've done this before and it seemed to work.
Wizardawd
Franklin, NC
Sure, removing the gap cap removes vapor pressure. But it's internal fuel line pressure we are dealing with here. So no the cap will do nothing in regards to line pressure, you have to starve or open the system to relieve pressure.
Wiz
Plus fuel vapor pressure generally only occurs in hot weather or long driving times.
dillon233
Member
Denver, CO
I cut a section of a normal 14mm closed end wrench out just big enough to fit around the fuel line. It worked great. I use that tool all the time now.
BpuVR4
Chicago
ran into the stripped nut problem even with much liquid wrench soakings. i almost tossed in the towel, before i just gripped it tight with a small high quality channel lock, and cracked it open using my floorjack handle as a breaker bar, using the throttle body as fulcrum. it was too easy.
