Looking to trade my 1976 Toyota pickup for a GVR4. Truck has a W58 5 speed trans from a 1980 Toyota Celica, Rebuilt 20R engine from a 1977 Toyota Celica bored .20 over. maybe have 15k on the rebuild. I converted the Electric fuel pump to a head mounted mechanical fuel pump. Also has Weber 38/38 synchronous carb. Alternator was replaced 3k miles ago. The interior has a new dash cap, Midship wood steering wheel and a Retrosound radio with aux hookup. there are 2 5 1/4" sony speakers mounted in the doors. Has the factory bench seat in great condition with only one rip on the passenger side, also a shift lever from a 1995 Toyota 4wd. The headliner is Dynamat. I Just found a different bed which explains the yellow/brown color. This one is rust free. If there's any interest please PM me and I can send more pics of whatever you want. Truck will come with the BBSs pictured which are off of a infinity they are 15x 6 1/2", also a set of 3 piece BBS RS 15x7. and the factory set of 14" steelies. Truck is lowered 2 3/4" in the front to keep proper control arm geometry and 3" in the back with blocks. Will also come with all the spare parts I have (Switches, Heater, Denso aux a/c, 74' hilux bucket seats, factory headliner,etc) also have a spare 4.10 rear diff, the current diff is a 3.90 from a 2000 4runner. I have all new seals for the steering box that may be put on before a trade. The truck is manual steering and manual brakes so brakes are stiff but not too bad.
I have driven this truck back and forth from New Mexico to Georgia 4 times and never had a issue. This is my DD.
The good:
New coil, voltage regulator and alternator.
New windshield seal.
New Stoptech Para Aramid pads and centric rear shoes with rebuilt calipers.
Tie rods and pitman/idler arm replaced 2k miles ago with Kasei 555 inner tie rod ends, adjusting sleeves and MOOG outer tie rod ends, the Ball joints are also relatively new Kasei 555 joints.
Control arm shafts recently cleaned and re-greased
New Silicone Rad hoses
H4 converted low/high beams with PIAA super plasma bulbs
New Taillight wiring harness
The bad:
This truck needs Some rust holes welded on the rocker panels I cut out the rotting to prevent spreading. The Only other rust besides the rocker panels are the cover metal for the body mounts on the inside of the cab.
Needs Paint
Drive-shaft may need to be balanced, I've been driving it like that since I got it running and it hasn't caused any problems but the small vibration is kind of irritating.
Windshield has a chip and wiper marks.
Its probably about time for new shocks.
The truck has a modified crossmember, so there is no mount for the parking brake. Parking brake inop.
Has exhaust leak between manifold and downpipe.
Price Range: TRADE
Range: 500+ Miles depending
Contact: PM or text 706-973-9713
Details: Looking for something that runs well for a daily driver, I don't care about cosmetics, minimal rust is ok. Mods are ok just let me know what they are.
