Looking for a Battery Relocation Tray for my GVR4. Previous owner put in trunk, not a fan, so I have a bunch of big gauge wire if someone wants it after I get a tray.
I build mine fairly simply with just a piece of sheet metal cut to fit the battery and folded the ends up so it doesn't slide. Use rubber lining to keep it snug.
What sort of room do you have under the hood? Is the intake in the stock position or moved to where the battery used to sit? A picture would be helpful to see where you want it mounted. Also, Odyssey makes a nice tray to go with their PC925 battery, might be a solution for you.
