Where to buy Stainless steel exhaust manifold studs?
Quoting mitsuturbo:
that's on the 2g T/E/L.. they have a 10mm stud on each end of the exh mani and 8mm studs all in-between
a common "upgrade/mod" is to tap out the end holes for a 10mm stud... it works wonders for sealing and holding the exh mani tight to the head
This is also present on the later 1g 7 bolt engine cylinder heads. I do this mod when I do a head.
jepherz
KC, Missouri
Quoting boostedinaz:
Stainless Studs.
I bought mine from these guys and they worked very well. I never had one break and swap out my exhaust mani a few times.
EDIT: They also have thread repair kits you can order at the same time if you have to fix any stripped threads.
+1. I've had my setup off probably 6 times with no issues. The stainless washers and nuts are easy to replace from a hardware store too in case you drop one...
