I finally figured out where those stupid wires go after searching. THANK YOU STURC!!!
Blue/Black, single wire sensor, A/C Condenser Fan, Normally open (removing wire)
Green/Red and Green/Black, 2 wire sensor, A/C Clutch lockout, Normally closed (removing wire)
Green/Black and Yellow/Green, 2 wire sensor, ECU Temperature sensor, variable ohm reading
Yellow/Green, single wire sensor, Cluster temp gauge, variable ohm reading.
