Water Injection - Intercooler Pipe or Manifold?
89coltgt
Ste Genevieve, MO
Sorry to jump in so late, but this is a great w/i thread! I think that the n/c valve is a good idea, but IMO, you don't want to make it too complicated just incase something does not change states and you run into a lean condition. The checkvalve at each injector will keep you from sucking water/meth at low rpms. Just my 2 cents.
cheekychimp
East Sussex, U.K.
The checkvalve works to stop water being drawn or sucked into the engine under vaccuum. An accumulator is a water reservoir stored under pressure which helps keep water pressures constant and reduces load on the pump. It however creates it's own problem in that if the solenoid activating the system failed and leaked, the entire contents of the accumulator would be injected into the cylinders under the stored pressure, even if the system and pump wasn't activated.
The additional solenoid and pressure switch is actually probably no different than the main one, but the likelihood of two solenoids failing at the same time is minimal.
ken inn
krum texas
imho, once you get a wi system installed and running, you will realize how simple the system can be, and still work. i have NEVER had a shurflo pump die. i did have the switch assembly leak, i think it froze and cracked. i also had that crap blue w/w fluid clog up the inlet filter(they dont use distilled water), and stop up the flow, but the pump still ran. a new pump assy is cheaper than just the switch assy. i think you install a simple system, then go wild after you get it dialed in, which dont take much. it's not like a fuel injection system where the water has to be metered exactly. think of it more like the fuel pump/pressure regulator system, where the flow dont have to be exact. some other facts to think about; the aquamist nozzle needs 45 psi to properly flow/fog. as you go up in psi, the flow increases, and the mist pattern changes. ie, at 45 psi, a nozzle will flow say, .5cc, but at 65 psi, it will flow 1.0 cc(i dont know the exact difference, just using these figures for an example). so, if boost is 20 lbs, wi pressure is 60 psi, nozzle no flow quite right. up the pump to 100, and the flow increases. so now you need to know how much at what psi, and at what pressures the flow changes, yada, yada. dont use aquamist nozzles? fine. they all got different flow characteristics, how do you find out what they are, and how do you regulate them? and, most important, what difference does it make? i am not convinced that altering the voltage to the pump really controls the amount of water that well. heck, it is hard enough to control at what boost it comes in at, no matter where you have it set. too much theory for me.
jogalant
Central FL
No. The mist is usually introduced into the mix post-turbo(or post-intercooler cold side/pre-throttlebody) so there is no chance of that happening.
Rausch
Cleveland, OH
Will the mist erode the compressor wheel over time if your not careful?
was kinda wondering that myself. i would think that you may see a little wear over a substantial amount of time, but without any overwhelming pressure or volume, i would assume it would come down to placement and flow. just a guess though. i'm sure someone knows better than i do, though. /ubbthreads/images/graemlins/crazy.gif
cheekychimp
East Sussex, U.K.
To prevent erosion of the compressor wheel you need to keep water droplets below 50 microns and ideally at about 10 microns. The nozzle pisces showed does that. If you inject up close and personal as he intends to right on top of the impeller, it should be fine. Pre turbo injection is actually nothing new.
Curtis suggested the possibilty of injecting water WITH my propane kit using a NOS fogger nozzle set injecting water/alky mix instead of fuel and propane instead of nitrous. At -40 degrees and roughly 400 psi it would cool down the compressor wheel somewhat. Maybe too much? Also I'm not sure what size water droplets these "fogger" nozzles would create.
jogalant
Central FL
I wonder if there is any data out there that shows an added benefit of introducing water injection pre-turbo. Absent that I say let the intercooler do its job then have the water injection after the intercooler. Seems this would offer a cooler charge prior to combustion, no?
cheekychimp
East Sussex, U.K.
YES, there is data. The point is that if you look at pre compressor injection from the stand point of cooling charge air ONLY, you have completely missed the point.
Substantially reducing the temperature of the charge air pre intercooler creates problems. Inject enough water and the intercooler becomers an interheater because all intercooler efficiency is lost and charged air temps at the intercooler outlet are HIGHER than those at the inlet.
This is pointless unless you intend to completely remove the intercooler and rely 100% on injection to cool the charge air, which incidentally quite a few people have done.
The object of pre compressor injection is to push compressor efficiency away from adiabatic to isothermic allowing the compressor to flow more at lower boost due to increased air density.
With a properly tuned pre turbo injection setup you can actually shift the entire compressor map. It is an ideal setup for high altitude and this was ONE of the reasons it was introduced in forced induction internal combustion aircraft in WWII to counteract the effects of altitude (thinner air).
I have said this before but no-one listens.
If you just want to cool the charge air, you are entirely correct, just do it after the intercooler, prior to the throttle body or at the intake manifold (i.e. direct port).
jogalant
Central FL
I see your point now about improving the turbo's efficiency. Frankly, I'd like to even eliminate the need for an intercooler. This might be the way to go... pre and post turbo.
If you're serious about water injection, and would like to read an excellent thread on pre-compressor injection, sign up on Aquamist's forum. http://www.aquamist.co.uk/phpBB2/index.php There's SO much good info there, it's almost impossible to sum it all up here in this thread. Go there, you'll see.
Also, as Paul said, there are a few caveats to injecting pre-compressor. I mentioned them earlier, but it was kind of muddled in the middle of a paragraph and not 110% clear. Here's a breakdown:
1) Inject directly into the compressor wheel if you can, not at a 90* angle to it.
Injecting directly into the compressor, at the correct distance from it, will keep water off of the walls of the intake pipe and mouth of the compressor cover where it can converge into larger droplets and wreak havoc on the blades of the compressor wheel. It's not cheap or easy to mount the nozzle pointed directly at the compressor wheel nut, but it's the best way to do it.
2) Inject with as fine a mist/fog as possible.
Again as Paul already mentioned, droplets in the 10-50 micron range are preferred. If they get larger than that they can start to really chew up the compressor wheel. The Bete PJ nozzles I mentioned earlier in this thread are perfect for this application.
3) A high pressure pump (100 psi+) is very preferable.
The higher pressure will contribute to greater atomization and smaller droplets. You might be able to get away with a 60 psi pump, but I wouldn't recommend it. And don't even think of running a 45 psi Shurflo pump!
Hope this helps...
