toybreaker
iconoclast
- Joined
- Apr 30, 2006
- Messages
- 3,581
It should be noted that since you're starting with a non efi car, they have probably sized everything for lower current draws.
This means the ignition switch is probably going to be overwhelmed if you try and set it up like a car that was designed around efi, as the switchgear in non efi cars is lighter duty.
Because of this, I would suggest you set-up all the hotel loads on designated relays, and use the key to only provide the signals to the relays.
Yes, starving the transistor for voltage/current could have damaged it.
Re-wiring things to provide it with clean power and replacing it will tell that tale.
I can't tell for sure, but is that a three pin relay? I am not familiar with the p/n or configuration...
I would strongly recommend you use a bosch style four pin relay when bodging things.
They generally have an antiflyback diode installed, and are fairly bulletproof. If one does fail, it's easy to find a matching equivilent unit in any town/village. They were (and still are) used in most german cars, and are fairly standardised.
Two 40 amp relays can handle everything engine related, and you can use an efi spec mpi relay to run the pump.
Be sure to draw up a digram for what you have done, and take some pictures so you will have a "road map" of sorts to guide you if troubleshooting things becomes necessary in the future.
