thecman02
Quoting Okayplayer:
We were leaving for the car show and the boost cut out @ 6 grand. From there on it would not boost past 0. We stopped @ a gas station and while the car was off I blew a coolant line. We replaced it onsite and the car drove fine to the show with no boost. I took the exhaust manifold off today. And both sides were spinning freely. I checked the oil line by spraying wd40 through it and it only weeped through the other side. I blew through it (yuck) and found it hard to blow thru. I noticed the outlet for the line is considerably smaller than the inlet. I have an oil line to feed from the ofh, but does that send too much oil pressure?
Too much oil pressure will manifest issues with boost coming on later, and oil getting around the seals making the car smoke. It won't stop the turbo from boosting until the turbo completely blows.
