Tranny fluid
Brunoboy
San Bruno,CA Home of SFO
i bought Mt-90 and a bottle of MTL today, I am gunna go and put the car on four jack stands, and start working on the oil leak, and the tranny, would a Rear main seal leak cause the clutch to mess up? I am also going to rebleed, and change the Axle seals and check the yoke on the Tcase
belize1334
Bozeman, MT
RMS leak could contaminate the clutch surface and cause it to slip. It don't see how it could cause disengagement issues though...
Brunoboy
So, uhm, I guess I didnt adjust it correctly. The slave was so soft that I can push the rod in all the way. and I could move the fork around, So I readjusted so that its solid, and re bled the slave for 20 minutes using almost a full bottle of fluid, with all that said and done, it shifts so smooth.....I bought the redline for nothing -___-, I might as well put it in ahaha, Thanks guys
I used royal purple throughout. It's got a rep for not sucking /ubbthreads/images/graemlins/grin.gif
