ken inn
if you look on the trans bell housing, right below the cylinder head, where it bolts to the block, it will have the numbers/letters STAMPED on it. W5M332----. N is what you want. W=you are hosed. nate pharr changed out the final drive in one, but the case itself is machined to accept the different final drives, and the close tolerances make it act like a pump, to lube other parts of the trans. also, if you remove the axles, and look thru the part where the axles go, if you can see clear thru, it is lsd. if you can see a round post, about 1" in dia blocking the way, it is NOT lsd. if it is lsd, you need a longer left(i think) axle to go thru and engage the lsd. these axles are like unobtanium. from what i understand, the rs trans wont grenade unless you are at speed, and then there is a lot of screaming. like, all 4 wheels lock up. scott evans at forced performance also knows a lot about the rs trans. the only way you can get it to work is to use the rear diff from the rs, also hard to get.
