Time For A Colorado Meet?
Galantvr4559
Denver, CO
I started it up and let it run for 10 seconds or so and I believe it jumped timing. It sounds real bad. And cams are off from each other now. I am so screwed.
I hate to say it but it sounds like whoever did the two seals recently either a: reassembled the timing components incorrectly or b: reused something that should've been replaced (timing and/or balance shaft belt) or c: failed to recognize that the hydraulic tensioner was on it's way out. Regardless, the first step you need to do is pull the front cover, reset the timing, and do a compression test. We'll go from there.
Overkill
Berthoud, CO
That is some serious suckage Brian! Do you know if your motor has balance shafts or not? Sorry if I you stated that and I missed it.
Galantvr4559
Denver, CO
Timing belt, mech tens, hydrolic tensioner, idler pulley all replaced less than 10k ago. Still under warranty. No I dont have balance shafts. I think maybe oil pump siezed and made timing jump. But I am no expert. I am contemplating finding a motor to transplant.
Galantvr4559
Denver, CO
When I had the seals replaced I had a new belt put on. If all this is caused by timing belt or stuff I had fixed it will be warrantied. I am not gonna mess with it. Im gonna let the shop I brought it to for timing stuff look at it.
Dark_Horse
Morrison, CO
I'd love to go to the meetup. The GVR4 may not make it though, since my ECU is fried. Am going to ship it out to Tom/Dave tomorrow, but I'm doubting that it'll be back in time for the meet next Sunday.
Galantvr4559
Denver, CO
So it looks right now that I wont be able to make it for the meet. The galant blew up sunday. Unknow whats wrong but will know more tonight.
Scott Y
Lakewood, Colorado, USA
I am planning on being there. I haven't had the car out to do anything this year, with work and house stuff and busy life stuff.
As an aside, I plan on going to the next Golden Supercruise which is on Sept 3rd. If you haven't been, there are hundreds of cars and it is quite an amazing show. The only GVR4 I've ever seen there is my own. Good times.
Ok, so far I've got:
Desmond (OkayPlayer)
Diego
Scott Y
(and another Scott, maybe the same one, I don't know)
My buddy Travis who doesn't frequent the forums, but owns a 92
Steven (biglady112)
David (dlesser) +1
Maybes:
Bryan (Galantvr4559)
Chase (makedollarz)
Dark_Horse
Unknowns:
John (toybreaker)
Overkill
LukeFrazier
GeorgeBillings
Diego, i'd love to. But i'm sitting in the springs outside of Jack's trying to pick up my clutch and flywheel that was supposed to be done tuesday, wasn't and then today, and it still isnt here. I'm being told six pm.
Diego
Yucky. I bought a smaller diameter bolt installed it and i have no gear, reverse will grind but I didn't force any gear to make sure it would still be safe... I'm out of ideas. /ubbthreads/images/graemlins/confused.gif
The transmission has 3 rubber vent tubes in the bell housing pull out the center 1 and look inside you can see the throw out bearing and you can see the clutch look for damage
