those with the AMG Wing
maroonmetallic
central WI
Quoting fuel:
I believe the 93 in the US came with a 2.4L SOHC 16V option, looks to be the same engine in the 7G Galants - but am wondering if it was 6 or 7 bolt and if the front and rear roll stopper mounts were still on the block?
It was a 7-bolt motor, but it's actually a 2.0l (16v SOHC)version of the 7G Galant motor. AFAIK it is a one year engine with a head similar to the 7G. It also has the taller deck height from the bottom of the engine block as compared to a 4g63 in the GVR4. The mounting of this engine was still found on the engine block as opposed to the transmission bellhousing.
Sorry for the off topic!
-Shawn
Brunoboy
San Bruno,CA Home of SFO
Quoting maroonmetallic:
I am almost certain that ANY 91 & earlier USDM Galant w/ a FACTORY spoiler had the brake light you need.
Most often those spoilers are found on GS, GS-x GSR & VR-4.
Hope this helps to clarify things!
-Shawn
can anyone else verify this at all? I dont want to have to go to a junk yard searching for this piece unless the lot has the right vehicle. Thanks
-Shane
maroonmetallic
central WI
Of all the Galants I have seen in both pictures & in junkyrds/running on streets.. that statement is true.
I'm Shawn & I approve of this message.
RedTwo
New Zealand
From the horses mouth or the horses... ASA?
E33A SNSS (Galant AMG,5FM/T)
PNC: 80356A
DESC: LAMP ASSY, HIGH MOUNTED STOP
Part No: MB529092
MMNA Mitsi's:
E38A:
1989.06.1 - 1990.05.3 ALL
1990.06.1 - 1991.05.1 ALL w/ABS
E33A:
1988.01.1 - 1990.05.3 SNGML2M, SNGML7M ALL
1989.06.1 - 1990.05.3 SRGML2M, SRGML7M w/option P26
1990.06.1 - 1992.05.3 SNXML2M, SNXML7M ALL
1990.06.1 - 1992.05.3 SNGML2M, SNGML7M, SRGML2M, SRGML7M w/ option P26
SNGML2M - Premium Line (DOHC), 5FM/T FED
SNGML7M - Premium Line (DOHC), 5FM/T CAL
SNXML2M - Premium Line (DOHC), 5FM/T FED
SNXML2M - Premium Line (DOHC), 5FM/T CAL
SRGML2M - Premium Line (DOHC), 4FA/T FED
SRGML7M - Premium Line (DOHC), 4FA/T CAL
Buggered if I know what you guys call your cars over there....
