The new 1902
trunks
Annandale, MN
Yeah the o2 is under the t stat. Where are the connectors in your first photo located in the bay? My emissions stuff is gone so I don't know specifics, but there should be a couple of electrical solenoids with vacuum lines going into them up there; or they'll need to be put back in there.
dsmtalontsi95
Glenville, PA
Figured some out. The all black one in the bottom pic is for the radiator fan and the sensor on the bottom of the radiator is plugged into the fan.
Does anyone know where I can get a drawing of the coolant hoses? I have deleted the water cooled oil cooler and the turbo I'm using doesn't have water lines either, so I have those looped together but I have a hose coming off the driver side bottom of the radiator and I don't know where it goes too. Anyone know?
dsmtalontsi95
Glenville, PA
Well the gas feed line ruptured when I tried to start it, I thought it was the gas tank. We got that all fixed and got the car to fire. It only ran off 2 cylinders so I will try 2 other injectors. We checked spark and we the plugs where firing, so we are thinking it's the injectors. Need to get better gas too.
I just changed my injectors 3 weeks ago. If I were you I would try to find someone here on the
Forum that has a couple fuel injectors they will
Sell. I found them brand new at ADVANCED auto parts and
They are $80 a piece and then I had to wait a week for them
To get there....I am in the AUTO parts and repair industry and
Even I still have issues with not getting the right parts..
I have looked through eBay and found a descent deal or 2 but there is no way to tell if you are Even gonna work.
