Since I've got a few minutes spare,
I'll quickly post up some pics!!
I've got a VR4 Galant (Aussie Spec)
And my brother has an AMG Galant which is being converted to a turbo 2.3L. Everything on the AMG is removable. No hacking of the chassis / loom etc whatsoever.
I have all the bits to make it stock again if I ever wanted to.
The VR4 on the other hand has gone to the dark side.
Enjoy the pics:
AMG AND VR4 (got new plates for the AMG, guess what is it?!?!?!)
VR4 OLD SETUP (2.3L Stroker with W2A - 330kw's on pump fuel - 25psi)
VR4 NEW SETUP (2.4L with A2A and Dry Ice to Air (not used yet) - 350kw's on pump fuel (run in tune) - 25psi) - still need to fab/install oil catch can - oil cooler - pwr steering cooler etc
VR4 Interior
VR4 exterior pics (DRAG SPEC - high suspension setting, more weight towards the front)
Some fabrication work
Brake setup look familiar guys?!?!
Hotbits DT2
The brains, AUTRONIC SM4. Best computer EVER!!!
AMG - STILL IN THE BUILD!!! Should be ready shortly!!!
Home made PLUGIN MOTEC adaptor (MOTEC M4 - basic but good enough for the AMG)
The ORIGINAL AMG intake manifold (larger plenum than the single runner US/AU spec manifold, but with the benifit of 2 runners with butterflies!!
Hotbits DT2 setup with Camaro calipers
FWD rear end... hmmmmmmmmm
The suspension setup took a while to sort out
Some AMG Fabrication pics
Engine is a 2.3L stroker - mild head work - mild cams (264 type) - my old turbo setup.
Aiming for about 250kw's at the front wheels (it's only a cruiser)
Running a Civic radiator and a bunch of custom parts.
Hopefully it'll work okay!
I am hoping to have them fully complete this year so I can run them down the 1/4 and try some track work (circuit).
I'd have to say, I recieved ALOT of support (with parts and advice) from you guys! I'll have to compile a list of the guys that specifically helped me out with my builds when I finish these 2 cars. This board has always been very helpfull and I do owe alot to you guys.
Thanks for looking!
------hmmmmmmmm that took longer than expected......off to dinner!
