Serpentine Belt Keeps Being Tossed
diambo4life
Edmond, Oklahoma
I am at my wits end about this. Everything looks ok but as soon as I make a 2nd gear pull, out goes the belt. The harmonic damper is not separated and both water pump and alternator pulleys are facing the right direction. Used two different belts with the same outcome. Loosening or tightening the belt has not made a difference. What else should I look for that I am overlooking? /ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/banghead.gif
strokin4dr
Savannah, GA
Mitsubishi alternator in stock location?
transparentdsm
Cherry Hill, NJ
^ this. I have a Jay racing relocation kit on my car and the kid I got it off had the shims backwards and the belt would walkvevery time I went about 3k rpm.
diambo4life
Edmond, Oklahoma
The pulleys are oriented correctly with the dish side facing the engine. Stock AZ alternator. Stock location. /ubbthreads/images/graemlins/mad.gif /ubbthreads/images/graemlins/dunno.gif Visually, there was no misalignment. I currently have it taken apart to fix a leaking crank seal.
It's gotta be an alignment issue, or damaged pulley.
You should be able to get a dial indicator on the crank and alternator pulleys to check for wobble. You can usually eyeball the water pump pulley and see if it's out of round.
I suppose the water pump could also be a potential cause. Check to see if its bearing is tight.
I'd probably remove the PS and water pump pulley sandwich and make sure the stack is good to go. If one of the pulleys isn't seating correctly, or is bent, you'll have an issue. If there's corrosion of the face of the water pump mounting flange, that could cause problems with the pulley stack not seating flush.
thomcasey
Indianapolis, IN
Also, the rebuilt alternators sometimes have a different pulley than stock
diambo4life
Edmond, Oklahoma
The crank is wobbling. Engine is coming out. What is weird, the car is running perfectly. I figured it out after the crank seal kept springing a leak. It was very obvious then. Oh well....Thanks for the help.
diambo4life
Edmond, Oklahoma
You can say that. /ubbthreads/images/graemlins/uhh.gif I have a spare crank. Just hoping my pistons/rods are ok. /ubbthreads/images/graemlins/dunno.gif Like I said, the car runs perfectly and if it was not throwing the belt, I would have never guessed this was happening. /ubbthreads/images/graemlins/shocked.gif
Sure it is not just the crank pulley separating?
Defiant
Houston, TX
/ubbthreads/images/graemlins/ooo.gif /ubbthreads/images/graemlins/crazy.gif /ubbthreads/images/graemlins/shocked.gif daaaamn
FlyingEagle
THE Ottawa
That was absurd. To the point of lack of noise, considering what happens when things are out by thousands, not by whole numbers ...
