Rear Subframe poly Bushings **comming to a end**
CP
West Simsbury, CT
The one I've got (pictured on the bottom) is not a 2 piece bushing. It's one solid piece of polyurethane with a metal sleeve through the middle of it.
jepherz
KC, Missouri
I can see from your picture that it IS a 2 piece bushing. One bushing has a machined finish on the top, the other is just molded. That, coupled with the fact that there are two part numbers on it, it looks exactly like the one I installed, and almost the same (besides the color) as the one in the link I provided should be enough to tell you otherwise.
GHETTOSwing
Sonoma County, CA.
I think these guys are the ones who make the the Polygraphite bushings
P-S-T
If you type Eclipse, eagle, or talon in the Model Search it will bring up all their items for them. For some reason the Sports & Import Polygraphite link/Page goes nowhere useful.
TylerAdamson
Iowa City, Iowa
P-S-T
Any chance of getting these in a solid aluminum piece or maybe some measurements so I can make some/get some made.
boostx
Orlando, FL
One of the poly ones are going to very hard , but i can get it made from aluminum if you want.
GHETTOSwing
Sonoma County, CA.
P-S-T
Oh, I'm not actually affiliated with them in any way, I would guess best bet would be to contact them? I just saw that Ray mentioned the company that did the polygraphite's.
