Powering Fuel Pump From Amp? *PIC ADDED*
Wizardawd
Franklin, NC
The bolt holding the rear bumper support yes. On the pump, no.
Make sure that you get as much of a paintless, large surface contact point as possilbe. And since the bumper support bolts are fairly beefy, you'll be able to attach a fairly large connector to it as well. Star washers do wonders as well.
Wiz
JSchleim18
Long Island, NY
OK So the bumper support part is a definite...now where would I attatch the other end to actually ground the fuel pump rewire? Do I need to take the fuel pump sending unit back out?
EDIT - It looks like I just need to run the 10G wire from the fuel pump itself to the ground point on the bumper support...Thanks!
marvinmadman
Lafayette, Louisiana
I had some issues once with my capacitor grounded there. I had to move it to the shock tower. The area was cleaned and everything... /ubbthreads/images/graemlins/dunno.gif
