On the value of heat shielding.
Vader
Active member
Portland, OR
Just finished installing my fp manifold mated to a big 16g yesterday, and damn that thing puts out some heat! I did a little research on ceramic coating the manifold, but apparently fp advises against it due to weaking the manifold material, although the two ceramic coaters I talked to disagreed with fp /ubbthreads/images/graemlins/dunno.gif I've had various other manifolds coated in the past with good results, fp is just special I guess! Ill probably go the blanket/shield route as soon as I sort out a few oil leaks /ubbthreads/images/graemlins/banghead.gif
G
zompton
Fp doesn't know what they are talking about, in fact they used to offer ceramic coatings but were doing it wrong so I think they stopped. I've been using ceramic coatings to control heat for about 16+ years and from my personal experience they do work if the material is prepped correctly and a high quality type/company is used. I don't get how other members here remove their engines, redo their bays, rebuild their motors but fail to incorporate heat management in to their builds until after the fact? /ubbthreads/images/graemlins/banghead.gif Heat management should be part of the build goal.
Wookalar
Arizona USSA
Quoting prove_it:
A solid pipe from turbo to IC? You must never need to service anything on your car.
I'm not really sure what difficulty people were having removing a small section of lower IC piping which led to this new fad of people using two pipes there but the couplers and clamps are quite easy to get to IMO. Especially on Mark's set up where his pipe runs over the top of the manifold, his comp housing coupler is exposed right in front.. My comp housing points down and I still have no problem loosening two T-bolt clamps when I need to remove the pipe. /ubbthreads/images/graemlins/dunno.gif
jepherz
KC, Missouri
Quoting G:
Didn't FP have issues with cracking on their first units though? Maybe they're saying if you contain all of that extra heat after putting on a thermal coating, the manifold composition isn't good enough and will crack? I agree, not much of an excuse though.
jnava
Arlington, Tx
Yes, Amber stated once that the longevity was compromised when using anything to keep heat from dissipating. She indicated that it would lead to cracks. So heat shields similar to our stock ones might be the solutions to the problem, otherwise, you can have premature failure on your FP mani.
