i've discussed this issue with a rally friend of mine, so far he says the pressures should increase only slightly.. he said if its going to 100 psi, thats really bad, but he believes that all the bs removals he has done hasn't really changed pressure at all
he said 5psi at most!
i will most likely wait till i get it up and running, and if pressure are high ill port it, if not, ill keep it as it is
also many of the balance shaft removal guys down here have kept the shaft in, so their pressure are all stock like..
would reversing the bearings really increase pressure by 30 or so psi?!?!?!
question, 100psi cold, what is it warm??
from what i recall, on my old motor (250,000kms) i also remember my gauge going up to 100psi cold start.. i thought i was normal back then..
5-50 oil..
