PJGross
Wiring to/around tank is pretty good. Car has sat in garage now most of its life. /ubbthreads/images/graemlins/smile.gif
However, I just ordered a relay and will rewire the fuel pump harness while everything is apart. I will just go into the car side wire harness, I am not going to re-wire all the way to the pump. This should remove any voltage drop from front to back of the car at least. I also made a mount plate for the new redtop optima and will have a 150A breaker at the battery, too.
Not sure where I'm putting the relay yet. I did order one that has a waterproof plug as part of it with the wire leads coming off. This should help keep it clean.
Getting this thing up and running is becoming a bigger project than I initially thought it would be.
There really isn't much left that is not new/refreshed after this so I should be able to move on to tuning fairly quick after this week.
-PJ
-PJ
