new owner 91 560/2000
clevr4
Rhoadesville, virginia
coyotes, just looking back over this problem and i know what you are talking about. i can keep my gnared tube and just clamp the dipstick with hoses. i will hit the store tomorrow. ^^^^ i will eventually change the tube. im guessing itsjust one bolt holding her in?
clevr4
PO emailed me the mod list... goes as follows.
Fidanza Flywheel
Act 2600 Clutch
Maf Translator
DKS 272 cams
H&K Springs
KYB AGX struts
GM 3.3 bar Map
Gm 3.5 inch MAF
AEM UEGO Wideband
1mm Oversized Valves
Bronze Valve Guides
Dual Valve Springs
Cometic Head Gasket
ARP head Studs
Ross Racing Pistons 8:5:1
Scat Rods
Toga bearings
Toga Oil Pump
solid setup?? thoughts? /ubbthreads/images/graemlins/dunno.gif
coyotes
Seattle, WA
Looks good, you should inspect all the wear and maintenance items and determine a priority in which to change them all out. If your car came with receipts or information about maintenance that would help. but I would suggest replacing everything depending on condition.
spark plugs (NGK)
plug wires (NGK)
coolant temperature sensor (OEM)
o2 sensor (OEM)
check condition of timing belt
do boost leak test
coolant system pressure test
engine compression/leakdown test
set base timing
set idle
turbohf
Lake Stevens, WA
my galant has a crimped dipstick, doesnt look as crushed as yours. i find that if the engine is warm its easier to pull out..
FlyingEagle
THE Ottawa
Quoting clevr4:
This is what im complaining about. i think i could come up witha better solution but for a quick fix i guess it works. any solution suggestions? /ubbthreads/images/graemlins/banghead.gif
[/url][/img]
Might I suggest a heat shield be put in place to keep your alternator alive, long term.
