need help with crank shaft bolt
dammitjim
WI
Soak it in PB Blaster if you haven't done that yet. Try hitting it with the impact on forward a few times too. Sometimes that will help break a bolt loose.
dsm10o0
San Jose CA
If nothing works, grab a very long pole about 5-10 ft long, take off the hood, put breaker bar pointing up, insert the pole and just yank on it.
*Just for safety, put the wheel on and put the car on the ground*
This problem happened to me once and broke a couple 1/2 ratchet and breaker bar but it decided to budge it self loose.
good luck man.
If the starter bump didn't do it, you're kinda hosed. Only other thing I can suggest is to hit the crank snout with some map gas and attempt the starter bump again.
Give me a brief explanation of how you're trying to get it off with the starter....
thedsmguy
Vancouver Washington
I built a tool once that was a junk harmonic balancer and a piece of 1" x 1/2" x 24" long steel stock and welded it on to the harmonic balancer so to hold the motor from turning. That has help me many times to get the damn things loose. Now I just have a 3/4 inch impact gun from harbor freight that cost me about $80 and I've yet run into a bolt it cant budge.
Good luck.
ercp98
northlake in illinois
at the moment i gave up. starter bump as per vfaq and turbowop's explanation.
using socket and breaker bar, i snug the breaker bar on to the bolt and rest it snug on top of the control arm.
i even used a jumper cable to another car(this car was running) to make sure the battery is good and the starter is getting full voltage. no luck.
i have it soaking with wd-40 at the moment. next time i will try heating the bolt by welding into it. i don't want to use a torch.
Adorsey
mass
The torch will do it, your going to replace the seal behined the sprocket anyway if you plan to take the front case off and do the balance shafts.
Dont hesitate with the use of that impact after the bolt is cherry red, she will come out. good luck
