need help selecting Gears
Rausch
Cleveland, OH
Quoting 1457gvr4:
Depends on who's driving the car. If its Terry driving then it wont make it around the block.
You have obviously never been in a car with OHB driving.
Lonewolf64
Birmingham, Alabama
I got the same type of explanation from John, and he said that my OE 1st gear would be fine when he built my transmission. So far, I've had zero problems with it on the current ~326whp setup. I haven't exactly babied it, but I haven't really given it a huge amount of abuse either. Street driving with occasional NLTS and studderbox launching.
Diego
well i know im over stock and well under OMFG this is crazy parts...... i will give them a call and see whats going on...
My Trans is fine EXCEPT the "OUTPUT" shaft got shredded when i put in the X-case.... so i just need a new output shaft, but a rebuild wouldnt be bad while its out....
You don't even need to drop the transmission to replace the output shaft. Pull off the endcase, remove the VC and slide it out to replace with another.
Diego
Wopper is there a write-up...(sketch) for that... so i can see what i have to pull down.... Terry whre are ya at with the pictures... /ubbthreads/images/graemlins/cool.gif
Diego
i still want to pull it... clutch is NEWer... about ~1k miles on that.. but could be stronger, anything past 15psi it starts to slip... its a stockish clutch... Damn Ebay Exedys
DR1665
Iowa City, IA
This going with a 1G 1st gear thing is news to me. I can't think of a single GVR4 rally car driver who would even consider it. And the only reason I've heard to replace it with anything else (typically an Evo III first) is for better acceleration. I'm no Mitsubishi transmission expert by any means, but the guys I know who are seriously abusing GVR4s off road for years on end seem to know what they're doing. Just seems weird that SO many people who are making SO much power would seem to have SO much trouble.
:shrug
CarRacer
Shakopee, MN
I think the key is the off road part. It would probably limit the abuse the transmission would take due to wheel spin.
It's just like launching on the street versus the drag strip. The traction on the prepared surface of a drag strip is very hard on a drivetrain. Thats my guess anyways.
Brianawd
Portland OR,
Rally car and street strip car are two way different things. You don't put close to the stress on first gear launching it in gravel as you do launching it on a sticky ass drag strip. Or even a tarmac rally.
If you want I can find the pic up my gvr4 1st gear after a 6k launch. It took every tooth off the gear. Putting a dsm 1st gear in has been around since 2001.
Evo 3 1st gear is great for a street car and auto cross car but not so great for a drag car. It just tall enough that it makes launching the car hard. Car tends to want to bog.
I wasn't even making that much power when I stripped mine. Was right after I installed the FPgreen and wasn't fully tuned yet. Just had a good launch and BOOM!, ripped the teeth clean off the gear.
