Just picked up #735--Plan to resurect it!!
gtluke
dirty jersey
Quoting Polish:
Welcome aboard, like Nate said ignore all the "It's not a DSM" comments...
They are elitist who think the Galant is better because it was made in Japan. Meanwhile these same people have no issue swapping in DSM 5 lug hugs, 4 bolt rear ends, shifters, springs, 2g MAFs, transmissions, 4ws eliminations, and so on... /ubbthreads/images/graemlins/rofl.gif
all that crap is built in japan anyway and assembled on the POS DSM chassis here. The DSM is a POS because the body and interior are utter piles of sh*t, and that's what is built here, most of the rest of it is shipped from japan and assembled on the turd.
fivestardsm
Middle, Michigan
Well... Where are the pictrures already? Put some up in the link at the bottom of my Sig
vvv. /ubbthreads/images/graemlins/wink.gif
NateCrisman
Blairstown, NJ
Quoting gtluke:
Quoting Polish:
Yeah, because DSM's have a bad reputation from ripped seats and broken unibodies. /ubbthreads/images/graemlins/banghead.gif
DSM's have bad reputations because of the parts shipped from Japan that came off the same assembly line or parts crate as every GVR4:
ecu caps
leaking valve stem seals & front case gaskets
timing belt failures from locking balance shafts
leaking & locking Xcases
grinding trans, bad clutch masters & clutchfork
flakey electronics that randomly die (CAS/coil/igniter/ISC/MAF)
alternators living in the worst environment possible
cracking turbine housings and manifolds w/ broken manifold studs
yeah...you know...all those things fail because they are bolted down to a turd DSM unibody by a union USA worker. And those things NEVER fail on a GVR4 unibody assembled in Japan by the masters. /ubbthreads/images/graemlins/rofl.gif
Everything that fails on a GVR4, fails because it's a mitsubishi. And a DSM is exactly the same thing and fails the same way for the same reason.
GTLuke is king of the Elitists and lives in a dilusional world where the magical powers of a Japan assembled unibody somehow makes all the "same-as-dsm" parts better.
curtis
Clarksville TN
/ubbthreads/images/graemlins/rofl.gif /ubbthreads/images/graemlins/rofl.gif /ubbthreads/images/graemlins/rofl.gif
Pictures will be posted as soon as it gets out ot the body shop...I am kind of embarassed by it's current state. /ubbthreads/images/graemlins/blush.gif
raptorWagon
Oak Harbor, WA
Don't feel bad, and rust shouldn't be too big of a deal hopefully. I have had to deal with a lot of rust on the rear end and still have an ongoing adventure and refuse to give up on it.
Body shop says it'll take 2 weeks to get done...I should be riding shortly after the New Year!! Then the Mods will begin after I give it a good "shake down."
