just ordered ecm link
yeti
san diego california
so this is my first data log on ecm link... and i have 6.3 counts of knock at the highest point is that bad?
also everytime i hit boost for about 3 seconds it slams and sputters out.
oh and idle raises to 2200 rpm upon a cold start and about 400rpms once warm.
idle surges the whole time until warm
o and a check engine light code 14 i think how do i view check engine lights?
Make sure you log into the ecmlink forums, you can get alot of help on how to do things there. I'll be using the Evo 8 Ralliart tune as my base tune. I found it on there.
yeti
i didnt know you could download preloaded tunes.
ive got a duplicate of this thread on the ecm forums and they are preety knowledgeable.
oh and viewing my log i have 7.4* knock/degrees which is like 23 counts of knock?
perdy bad...
this is the way everything was setup i havent adjusted any setting's
and the car tuns the same as it had before i plugged the link in so no issue there.
and someone said my tps voltage was (.43v at 0%throttle) and (.4v at 0% throttle) in other spots
OMFGeofffff
Burnsville, MN
Check your connector at the tps. Also try a different tps or adjust it correctly. Also I don't want to sound like a dick but you should also try to use spell check and and proper grammar. It's frustrating actually TRYING to read something when you should be able to read through it and understand the first time.
Adorsey
mass
you can simulate the tps also, so you dont even need the sensor plugged in
yeti
sorry I have been really trying to look over my posts before i send them out.
My apologies i will be reviewing my posts before hand
yeti
how do i simulate sensors, i just figured out how to add captured values.(like TPS voltage,, and AFR est.) are now added to my log...
i am going to go watch some ecm tuning demos now
boostedinaz
Scottsdale, AZ
Here is my advice. Stop just asking questions and read about the product you have already purchased. You will be amazed how much info you can find by just looking and reading and not hoping to be spoon fed.
Yes I know you are new to all this, but so was everyone else at some point. If you don't take on the task of learning for yourself then you will be nothing but frustrated.
1qkfwd
Sun Valley, NV
You should be posting over there on the link forums. Thats what they are there for. Read the entire wiki section before you ask questions though. It explains all about ecmlink and all the functions of ecmlink. From there if you have questions post up in the forums and im sure you will get your anwsers. If you dont read through the wiki first be prepared to get flamed.
